ahyltonnj
Apr 22, 2016Aspirant
Device Names are not appearing in Netgear Genie for R7000
I am running firmware V1.0.4.30_1.1.67 and none of my device names are appearing under Netgear Genie browser page. I see IP addresses and MAC addresses but not Device Names. They used to appea...
- Apr 25, 2016
The beta link is now updated.
You may proceed in downloading the file.
IrvSp
Apr 23, 2016Master
Mine appear?
However I've had this router for a LONG time (I'm now on the lastest official Beta). I might have had to enter the names for the devices myself a long time ago? However it is possible I didn't need too? Reason is the KINDLE above. I wouldn't have left it with that name, especially the numbers behind it?
In any event, I think you CAN enter meaningful information for Device Name under ADVANCED --> SECURITY --> ACCESS CONTROL. There you can select a device and EDIT it's name:
- ahyltonnjApr 24, 2016Aspirant
See picture. They used to. I was wondering if the router picks up name. I had them before but now they don't.
- IrvSpApr 24, 2016Master
Reset the Router (hidden button recessed on back, hold it down until the power light flashes) and re-enter all your settings, maybe that willl fix it?
Might work if you export the settings, reset, and import.
Could also try the beta and see if it works
Where do I find the beta? I am currently running firmware V1.0.4.30_1.1.67. Thx
