ahyltonnj
Apr 22, 2016Aspirant
Device Names are not appearing in Netgear Genie for R7000
I am running firmware V1.0.4.30_1.1.67 and none of my device names are appearing under Netgear Genie browser page. I see IP addresses and MAC addresses but not Device Names. They used to appea...
- Apr 25, 2016
The beta link is now updated.
You may proceed in downloading the file.
ahyltonnj
Apr 24, 2016Aspirant
See picture. They used to. I was wondering if the router picks up name. I had them before but now they don't.
IrvSp
Apr 24, 2016Master
Reset the Router (hidden button recessed on back, hold it down until the power light flashes) and re-enter all your settings, maybe that willl fix it?
Might work if you export the settings, reset, and import.
Could also try the beta and see if it works
- ahyltonnjApr 24, 2016Aspirant
Where do I find the beta? I am currently running firmware V1.0.4.30_1.1.67. Thx- IrvSpApr 25, 2016Master
You can get it from here, https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-60/m-p/1070857#M30302.
If you have a problem after install try doing the hard reset back to factory settings and then redo all your settings.
- ahyltonnjApr 25, 2016Aspirant
When I click on the link it asks for a File Code.
