Hydro89
Jan 25, 2022Aspirant
devices connecting
So I have a nintendo switch and it will not connect to the server. The password is right I already tried with nintendo support and they are no help.
Jan 25, 2022Guru - Experienced User
Won't connect to the server?
Or won't connect to the router?
A little unclear on what is actually happening.
what firmware is on the router?
What modem/gateway is the router connected to?
- Hydro89Jan 26, 2022Aspirant
It connects to the router but not the server. I need I think to open the port forwarding thing.
- michaelkenwardJan 26, 2022Guru - Experienced User
Tell us in a bit more detail what is going on.
How about the other questions from plemans? In particular, what modem/gateway is the router connected to?
What are the messages that you see when you connect to the router?
What makes you think that?
Talk of "the port forwarding thing" doesn't mean much unless you know what you are doing. For that you need to ask the people who support the Nintendo switch.
This may help:
Search - NETGEAR Communities – Nintendo Switch
i have netgear modem idk gateway i talked to my net provider he said port forwading he said call my router support and i talked to nintendo they said to talk to my net provider but i click connect to net it connects to the wifi but fails to connect the the server thts what it says
