Hydro89
Jan 25, 2022Aspirant
devices connecting
So I have a nintendo switch and it will not connect to the server. The password is right I already tried with nintendo support and they are no help.
Hydro89
Jan 26, 2022Aspirant
It connects to the router but not the server. I need I think to open the port forwarding thing.
michaelkenward
Jan 26, 2022Guru - Experienced User
Tell us in a bit more detail what is going on.
How about the other questions from plemans? In particular, what modem/gateway is the router connected to?
What are the messages that you see when you connect to the router?
What makes you think that?
Talk of "the port forwarding thing" doesn't mean much unless you know what you are doing. For that you need to ask the people who support the Nintendo switch.
This may help:
Search - NETGEAR Communities – Nintendo Switch
- Hydro89Jan 26, 2022Aspirant
i have netgear modem idk gateway i talked to my net provider he said port forwading he said call my router support and i talked to nintendo they said to talk to my net provider but i click connect to net it connects to the wifi but fails to connect the the server thts what it says
- michaelkenwardJan 26, 2022Guru - Experienced User
Hydro89 wrote:
i have netgear modem ...
What is it? So far all we know is that you have an R7000. That's a router, not a modem.
Netgear has made dozens of modems over the years. Many are modem/routers. That makes life complicated.
Look on the back of your modem.What is the model number?
- Hydro89Jan 27, 2022Aspirant
i have a night hawk router thats the r7000 i have a seperate moden just a reg netgear modem CM1000v 2
