JerseyBiker
Jul 23, 2015Aspirant
Devices losing connection on V1.0.4.30 firmware
I have a R7000 I purchased March of 2014. It's on 24 hours has worked without hardly any issues until the last firmware upgrade. I have many wireless devices including 2 Windows laptops, 2 Android ta...
- Jul 23, 2015
Did you factory reset router before and after upgrade? That's best way to ensure all of the fw upgrade works. Gets rid of any nasty artifacts (config or old fw realted) and loads any new drivers that may be included in a fw release.
netwrks
Jul 23, 2015Master
- JerseyBikerJul 23, 2015Aspirant
netwrks wrote:Did you factory reset router before and after upgrade? That's best way to ensure all of the fw upgrade works. Gets rid of any nasty artifacts (config or old fw realted) and loads any new drivers that may be included in a fw release.
You know I didn't think about that. It's not that I never knew about a factory reset but for some reason I just forgot. As a matter of fact I don't remember ever doing a reset on this router and I have had several updates. Well I'm going to do it now. I'll let you know in a few days if it resolved my issue. Thank you very much for the very fast reply.
- dendmanJul 27, 2015Tutor
I can verify the R7000 issue with the latest .30 firmware, very nasty bug it really hosed the network\router on the 5G side and affected overall performance...I had to revert to .28 to rectify and will not update until this is been fixed.
- egiprimeJul 30, 2015Aspirant
Im having dissconnects all the time since the last update as well. I have never had any problems for a year and now it wont stay connected.
I did a reset but the latest firmware stayed? I thought it was supposed to reset everything?
- JerseyBikerAug 05, 2015Aspirant
Netwrks I think you were correct. It's been almost 2 weeks since I did the factory reset and I haven't had any issues since. Even 5ghz which was acting weird not connecting at all sometimes casuing me to only use 2.4ghz is working OK now. I probably had 2 or 3 firmware updates without a factory reset. It's not something I'ts not something that I wasn't aware of, I guess I just forgot about it. Thank you very much.
- netwrksAug 05, 2015Master
Good to hear all is well..
