JerseyBiker
Jul 23, 2015Aspirant
Devices losing connection on V1.0.4.30 firmware
I have a R7000 I purchased March of 2014. It's on 24 hours has worked without hardly any issues until the last firmware upgrade. I have many wireless devices including 2 Windows laptops, 2 Android ta...
- Jul 23, 2015
Did you factory reset router before and after upgrade? That's best way to ensure all of the fw upgrade works. Gets rid of any nasty artifacts (config or old fw realted) and loads any new drivers that may be included in a fw release.
JerseyBiker
Aug 05, 2015Aspirant
Netwrks I think you were correct. It's been almost 2 weeks since I did the factory reset and I haven't had any issues since. Even 5ghz which was acting weird not connecting at all sometimes casuing me to only use 2.4ghz is working OK now. I probably had 2 or 3 firmware updates without a factory reset. It's not something I'ts not something that I wasn't aware of, I guess I just forgot about it. Thank you very much.
netwrks
Aug 05, 2015Master
Good to hear all is well..
