kingsc
Jun 01, 2023Aspirant
DHCP Option 82
Does the R7400 router support this option? I noticed in packet captures that when I send that option, the DHCP service doesn't respond, but does just fine if I don't include it.
- Jun 01, 2023Nope, not supported.
Jun 01, 2023Guru - Experienced User
Might check NGs support page and user manual for this option.
https://www.netgear.com/support/
Or with in the routers web page. Maybe seen under Advanced tab/Setup/Internet or under Advanced Tab/Advanced section.
If you don't see this feature displayed anywhere, may not be supported.
microchip8
Jun 01, 2023Master
- kingscJun 01, 2023Aspirant
Yeah I didn't see anything about it in the user manual. Bummer. I need this option to support an important endpoint identification feature in my management platform.
- microchip8Jun 01, 2023MasterOption 82 is an "exotic" one, and I haven't come across it in any consumer router over the years. Only option 60/61 are usually supported as required by some ISPs. Option 82 might be supported in the more professional-oriented devices.
