fobot
Feb 08, 2019Aspirant
DHCP wan disconnect
Hi
I’ve recently changed ISP’s and run into a bit of an issue
Previously , I was using ppoe and had no issues, but my new isp (Vodafone in Australia vdsl2) connects using ipoe
They issue a 1 hour lease and every hour I get a 5 second or so disconnect. Is there a setting I’m missing? On the latest firmware .70
Thanks
Thanks
You are in the wrong forum. Modem Routers are covered here, https://community.netgear.com/t5/DSL-Modems-Routers/bd-p/home-dsl-modems-routers. Might have better luck posting there as others frequenting there might have some answers for you.
- fobotAspirantOk definitely a router specific issue, using the cheap isp supplied modem and it works fine, can’t get a full hour out of the Netgear
I turned off dos protection still no luck. Is there any Netgear support or way to send through logs? - IrvSpMaster
