sohcrates
Jun 30, 2016Follower
Did R7000 1.0.6.54 get pulled?
All links to 1.0.6.54 seem to lead nowhere. "Requested file does not exist" Another failed beta? Are we going to just give up on Arlo support for this router? I think at this point, for our troub...
spopiela
Jul 26, 2016Guide
Can you backup settings in router, then flash and then pull in the backup cfg settings file.
IrvSp
Jul 26, 2016Master
Not advisable. The data can change between f/w versions. Only reliable when re-flashing the SAME version after you install it and reset. Other case would be if you made changes and didn't like them and wanted to restore the settings you had before changing them. This is especially true if you are going backwards in versions.
However I guess you could try it, but if you have problems, RESET and then manually enter required settings, but it isn't advised to do this.
- spopielaJul 26, 2016Guide
I'm not sure what settings I changed from factory default. I have at least 8 port forwarding settings that I added. Will those change? Is there a way to get a list of settings that one needs to record befor a factory reset is done.
