sohcrates
Jun 30, 2016Follower
Did R7000 1.0.6.54 get pulled?
All links to 1.0.6.54 seem to lead nowhere. "Requested file does not exist" Another failed beta? Are we going to just give up on Arlo support for this router? I think at this point, for our troub...
spopiela
Jul 26, 2016Guide
I'm not sure what settings I changed from factory default. I have at least 8 port forwarding settings that I added. Will those change? Is there a way to get a list of settings that one needs to record befor a factory reset is done.
IrvSp
Jul 26, 2016Master
Not that I know of? I'd suggest taking SCREENSHOTS of each page and use those as a guide.
- spopielaJul 26, 2016Guide
Thank You... great idea!
Click on Apply button on every page to change setings after factory reset? I am geting along in years, so I hate to keep using up remaining Lifetime .. You have been helpful! A modern household, as I have, with all kinds of home automation, cameras, advanced HAM radio, security systems and the "plain vanilla" computers has created the most challenging task in electronics... Routers! The R7000 is a great router for me, I struugle to keep up with updates to firmware when a new option arises, like Arlo. The support on Netgear tends to fade away after a new release. Companies need to release firmware in the same way that hardware was released when i was an engineer. Test it, test it and test it some more until everyone is happy. Thank You
- spopielaJul 28, 2016Guide
I have OpenVPN also set up on the router. Do any openvpn settings get erased in the router with a factory reset? It is a pain to set up and I can't really test it from home. It is taking me a lot of time to do R7000 firmware changes when a factory reset is called for.... very painful process.
