CharLans
Nov 07, 2020Follower
Difficluties Setting Up EX7700 extender
Dear Community, I am having trouble setting up my EX7700 extender. It had been set up with a different router but I had to recently change to a new one. Doing that, however, has meant that I ca...
antinode
Nov 07, 2020Guru
> What do I need to do so that the extender, configured to a router and
> wifi system I no longer use/have, can be configured to my new
> router/wifi?
Have you considered trying the the obvious?
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Factory
Default Settings" and/or Return the Extender to Its Factory Default
Settings". Do that. Then, start at the beginning with your newly
virginized extender. Its User Manual might be helpful with that
operation, too.
