DarkyD123
Jul 03, 2021Aspirant
Direct connection to VM Hub 500Mb, with Nighthawk 230Mb
We decided to bite the bullet and take Virgin Media up on their Oomph bundle for several reason, one being the 600Mb internet access. So did the research and with being a gamer and having 15+ various internet necessary bits of kit opted for the Nighthawk R8000 to cover all bases. The problem I have is it won’t output anything over 150Mb (wired) wireless is the same and that’s expected. However wired direct to the VM Hub3 I can get anything above 500Mb. If I factory reset the NHX6 switch off wireless (just to test) and have one laptop wired to the NHX6 with VM Hub3 in modem mode, for about 3mins it will test speed at around 430Mb then drop to around 230Mb and pretty much stick around there or drop lower and never increase. The Virgin Media Hub (wired) will always report anything from 450Mb and above for the entire duration but it drops when connecting via the NH. I would prefer to manage my own network and like the config for the NightHawk but the lose of bandwidth availability is killing the pocket for the extra spent on the router and VM package deal. I get the same connection speeds when all the devices are hooked up. Can anyone explain or advise the cause for the lose of bandwidth via the NHX6? It has the latest firmware and there is nothing odd configs, no QoS etc enabled
running 2 routers cascaded can cause issues. its called a double nat.
What is Double NAT? | Answer | NETGEAR Support
1 thing you can try doing if you want both the VM hub and the netgear is to put the netgears IP address into the VM hub's DMZ.
Of if you only need the netgear, you can either put the vm hub into passthrough/modem only mode or the netgear router into access point mode.
- DarkyD123AspirantThanks for the response.
The VM Hub is in modem modem (throughput only) to try and solve the issue of double NAT’ing. Tried speaking with VM technical support about the option to switch it off at their end which they either can’t or won’t do. If the NHX6 is put in to AP mode and you manage the VM box (not recommended just due to lack of config/security options) for whatever reason no internet and I don’t really like this option for management.- plemansGuru - Experienced User
Sadly, it wouldn't be the first ISP supplied modem/gateway that didn't function properly in passthrough mode.
Its why we sometimes recommend the ISP device in router mode (disable its wifi) and the netgear in access point mode.
Or try putting the VM hub in router mode (wifi disabled) and put the netgears IP address into the VM hub's dmz.
