sharadmitra
Dec 11, 2020Aspirant
Disable 2.4Ghz
I would like to disable my default 2.4ghz network and only use 2.4 Ghz for guest network to connect smart devices in the home and prevent any home network intrusion attempts. For other home devices such as computers, I use the 5ghz bands.
Scratch the idea that 2.4GHz or 5GHz or Guest_24G anf Guest_5G are network.
Essentially you have a kind of two networks:
The primary, normal one with the LAN ports plus wireless devices associated to the router network by the "normal" SSID(s).
The second, intended for guest usage, where wireless guests (or for the sake wireless IoJ) devices can associate to the guest network. By default, these devices can't see each other, and each device can connect to the Internet only. There is an optional control for the guest network(s?) where you can enable "Allow Guests to see each other and access my local network". This is not what you want of course, so the only choice is operating the guest network without this additional allowance. This does lead to the situation that each device on the guest network can only access the Internet, the IoJ cloud only. Making it little bit difficult if the IoJ need to communicate - especially if it's for home automation and the Internet is down.
To be technically exact, these devices have only one network, one LAN, one IP subnet. The guest network MAC addresses are just L2 filtered, so (by default) these guest devices can reach only the Internet, but not the other devices on the WLAN and the LAN ports. Be aware for testing that the devices on the "two" networks can ping each other, also the DHCP service is the very same. Any other services are not reachable
There is no reason to operate the IoJ guest network only on one wireless radio. There is no added security. You are only crippling the wireless availability and coverage for your "normal" devices. Said that: For these reasons, there is no such software control available.- sharadmitraAspirantSo if 2.4 guest is enabled alongwith the other 2.4ghz all different SSIDs, it will create a mess on 2.4 Ghz with all the neighboring 2.4 ghz.
Both the normal and the guest SSID run on the same radio interface, the same channel and other wireless radio settings. One more or one less does not mach much of an advantage in a dense wireless environment.
The wise decision for the normal WiFi is using what Netgear does designate as Smart Connect - one SSID for all radios anyway, so the clients have a choice to use the best one.... Unfortunately, this is not available for the guest notwork settings.
