GJensen71
Aug 10, 2021Follower
Disable 5ghz Antennas on a temp basis: How?
I have a wifi-enabled device that is failing to connect to my 5ghz antenna while doing an upload and the device maker said I need to disable 5ghz and use the 2.4ghz channel instead. Where in the app...
Aug 10, 2021Guru - Experienced User
1. the orbi devices don't have the ability to disable 5ghz entirely.
2. what device is it that you're having issues updating?
