monkey211
Jan 23, 2022Follower
disable charging when tethering
Is there a way to disable charging when I am tethering via the USB c port? I tether to my MacBook pro, but I don't want to charge my mr1100 from my MacBook pro when tethering.
- Jan 24, 2022
If you want more than the answer from microchip8 you should ask in the place where they talk about the MR1100.
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
microchip8
Jan 23, 2022Master
No
