FURRYe38's avatar
Disable DNS Relay on R9000
Sorry if this question has been asked before. It's been a while since I had been using NG.    I was curious of DNS Relay could be disabled on the R9000 or if NG keeps this feature closed on there p...
  • TheEther's avatar
    Dec 17, 2016
    Netgear does not offer the option to disable it.  You can upvote my request here.
