Networkingjoe
May 08, 2024Aspirant
Disable external Access
How do you disable http access to the router. When I type http://myip into a browser, I get a login prompt to routerlogin. How do I disable that?
- May 09, 2024
Are you trying this from a remote location outside the home or trying this while at home on the same network?
michaelkenward
May 09, 2024Guru - Experienced User
What are you trying to do?
Tell us the end result that you want. There may be other ways of reaching the final destination.
- NetworkingjoeMay 09, 2024Aspirant
Removed post as it was not needed.
