Networkingjoe
May 08, 2024Aspirant
Disable external Access
How do you disable http access to the router. When I type http://myip into a browser, I get a login prompt to routerlogin. How do I disable that?
- May 09, 2024
Are you trying this from a remote location outside the home or trying this while at home on the same network?
microchip8
May 08, 2024Master
routerlogin is a local hostname that points to the router's IP address. External access is by default disabled.
Networkingjoe
May 09, 2024Aspirant
Microchip8 - I did not turn it on and would not enable that, however, I did update the router 2 weeks ago. How do I turn it off? I have looked through all the settings and nothing stands out.
michaelkenward- I would like to disable HTTP access from my external NAT. Internally is fine but I do not want exposure externally.
- michaelkenwardMay 09, 2024Guru - Experienced User
External http access isn't enabled.
Netgear disabled external ways in when it killed remote management and and ReadyCLOUD.
- NetworkingjoeMay 09, 2024Aspirant
When I hit my external ip, issued by the ISP, I get a prompt for a login for routerlogin.net. How do I get rid of this prompt?
- FURRYe38May 09, 2024Guru - Experienced User
Check for Remote Access features under advanced Tab, Security or Admin. If you seen check box for this feature, uncheck the box and apply.
What FW version is loaded on your router?
