Networkingjoe
May 08, 2024Aspirant
Disable external Access
How do you disable http access to the router. When I type http://myip into a browser, I get a login prompt to routerlogin. How do I disable that?
- May 09, 2024
Are you trying this from a remote location outside the home or trying this while at home on the same network?
michaelkenward
May 09, 2024Guru - Experienced User
What are you trying to do?
Tell us the end result that you want. There may be other ways of reaching the final destination.
Networkingjoe
May 09, 2024Aspirant
Removed post as it was not needed.
