Networkingjoe
May 08, 2024Aspirant
Disable external Access
How do you disable http access to the router. When I type http://myip into a browser, I get a login prompt to routerlogin. How do I disable that?
- May 09, 2024
Are you trying this from a remote location outside the home or trying this while at home on the same network?
Networkingjoe
May 09, 2024Aspirant
When I hit my external ip, issued by the ISP, I get a prompt for a login for routerlogin.net. How do I get rid of this prompt?
May 09, 2024Guru - Experienced User
