Networkingjoe
May 09, 2024Aspirant
Disable external Access
How do you disable http access to the router. When I type http://myip into a browser, I get a login prompt to routerlogin. How do I disable that?
- May 09, 2024
Are you trying this from a remote location outside the home or trying this while at home on the same network?
May 09, 2024Guru - Experienced User
Networkingjoe
You are 100% correct. I was hitting my external nat from inside to the outside and did not even think to test it completely offsite. Thanks everyone for the help.
- FURRYe38May 09, 2024Guru - Experienced User
Ya if your on the LAN side, data is still going to get to the router on this side.
Try at a remote location away from home. Shouldn't see the log in for the router here.
Good Luck.
