CliveP
Nov 07, 2020Follower
Disable modem on AC1900/D7000V2
Hi,
I have an AC1900/D7000V2 VDSL/ADSL Modem Router and now would like to use it just as a router. Is there a wau to reconfigue it to be able to use it as a wireless router within my existing network?
1 Reply
> [...] D7000V2 [...] Is there a wau to reconfigue it to be able to use
> it as a wireless router within my existing network? [...]Your "my existing network" comprises what, exactly?
What is the actual problem which you are trying to solve? Would you
like to extend your wireless-network coverage, or something else? That
is, do you want to use the D7000v2 as a wireless access point (which
would be typical), or as a full-function _router_ (which would be
unusual), or what?Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Use the Modem
Router as a WiFi Access Point". (Or, if your really want to use it as a
router, "Set Up the Modem Router for Cable or Fiber Service".)
