joenetcomm
Oct 20, 2020Tutor
Disable WPS on R9000 Nighthawk X10 AD7200
I read this KB on the subject: https://kb.netgear.com/19824/How-do-NETGEAR-Home-routers-defend-WiFi-Protected-Setup-PIN-against-brute-force-vulnerability It says this: To disable the Rout...
- Oct 21, 2020when your in advanced tab, is there a wps wizard on the left? if so, click that.
I can't see because not everything is showing. You got just enough :)
joenetcomm
Oct 21, 2020Tutor
plemans wrote:Do you have a screen snip of what you actual see when you go to that location?
Thanks for your reply. Here's a screenshot:
Regards, Joe
Oct 21, 2020Guru - Experienced User
photos have to be approved by a mod. it takes time. you can do the "choose file" option at the bottom and add it.
