joenetcomm
Oct 20, 2020Tutor
Disable WPS on R9000 Nighthawk X10 AD7200
I read this KB on the subject: https://kb.netgear.com/19824/How-do-NETGEAR-Home-routers-defend-WiFi-Protected-Setup-PIN-against-brute-force-vulnerability It says this: To disable the Rout...
- Oct 21, 2020when your in advanced tab, is there a wps wizard on the left? if so, click that.
I can't see because not everything is showing. You got just enough :)
Oct 21, 2020Guru - Experienced User
joenetcomm
Oct 21, 2020Tutor
Ah, very nice! Turns out that WPS requires a client to be installed and the WPS Wizard allows you to pick either the Push Button (recommended) or the PIN Number (see attached screenshot). Since I haven't configured a WPS client, I presumably have no WPS support (neither Push Button nor PIN Number), which is fine with me. Thanks for your help...very much appreciated! Regards, Joe
- antinodeOct 21, 2020Guru
> Turns out that WPS requires a client to be installed [...]
No. The "WPS client" is the computer/device which you are trying to
connect wirelessly to the router.If you leave the "PIN Number" button unselected, then I'd expect the
PIN method to be disabled.Regarding "PIN Number", see: http://antinode.info/complaints/aer.html
- joenetcommOct 21, 2020Tutor
> If you leave the "PIN Number" button unselected, then I'd expect the PIN method to be disabled.
But I'd like the PIN method to be diabled entirely, not just for a specific device, because, to quote from the Netgear KB, "Since only the Router PIN method is vulnerable to brute force attack, NETGEAR recommends disabling this function to best protect your network from invasion."
So, is it disabled by default entirely on the R9000? If not, how to do it? Regards, Joe
> specific device, [...]Sorry. I read your picture carelessly. The "WPS Wizard" is not
where that's determined. According to the R9000 User Manual, what you
want would be at ADVANCED > Advanced Setup > Wireless Settings : Enable
Router's PIN (or not).As you quoted above, "Go to Advanced Setup menu and select Wireless
Settings. Under WPS settings, [...]". Note that "WPS Wizard" and"Wireless Settings" are spelled differently for a reason.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "WPS". Keep
looking until you find "Specify WPS Settings".
