joenetcomm
Oct 21, 2020Tutor
Disable WPS on R9000 Nighthawk X10 AD7200
I read this KB on the subject: https://kb.netgear.com/19824/How-do-NETGEAR-Home-routers-defend-WiFi-Protected-Setup-PIN-against-brute-force-vulnerability It says this: To disable the Rout...
- Oct 21, 2020when your in advanced tab, is there a wps wizard on the left? if so, click that.
I can't see because not everything is showing. You got just enough :)
antinode
Oct 22, 2020Guru
> I know nothing about it, and a search of the user manual comes up empty
> for both smart connect and smartconnect.
If the R7000 User Manual is any guide, then it'd be under BASIC >
Wireless.
If the firmware says "disabled when smart connect is enabled", but
there is no Smart Connect feature in the firmware, then I'd be looking
for a different firmware version. (I'd like to say that they can't all
be this buggy, but I've learned not to be so optimistic about Netgear
router firmware.) In case you don't already know the way:
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions. (In the User Manual, look for "firmware", and,
especially, for a topic like "Manually Upload Firmware to the Router".)
joenetcomm
Oct 22, 2020Tutor
Good catch!
> it'd be under BASIC > Wireless
It is (but the manual has no mention of Smart Connect in that section...or, for that matter, anywhere in the manual).
> looking for a different firmware version
As I mentioned in the initial post, I had already upgraded to the latest firmware (V1.0.5.24) before posting.
After un-checking Smart Connect, the WPS settings came to life. Attached two screenshots show the PIN enabled and disabled.
Thanks for catching the Smart Connect issue...much appreciated! Regards, Joe
Edit: Seems that you can't attach more than one file in this forum. I'll put both screenshots inline...hopefully, the Mods will be around to approve them.
