ArwinH
Mar 10, 2024Aspirant
Disable XfinityWifi network
I have Comcast/Xfinity as an internet provider and I would like to stop broadcasting their signal (Xfinitywifi) from my Wireless Router. When I called Xfinity they said that only Netgear can disabl...
michaelkenward
Mar 11, 2024Guru - Experienced User
As Kitsap says, you haven't provided enough information.
If you have an Xfinity modem/router from, then that's where to look for the on/off switch for the Xfinity wifi.
If you have an Xfinity modem/router connecting your Netgear router to the Internet, it isn't just the wifi that you may have to think about.
