georgeparadisis
Oct 26, 2022Follower
disableing 5g band steering
I need to disable 5g band steering so I can connect tp-link wifii extender.
Oct 27, 2022Guru - Experienced User
No much to go on. Is there a NG product your referring too?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.
