georgeparadisis
Oct 26, 2022Follower
disableing 5g band steering
I need to disable 5g band steering so I can connect tp-link wifii extender.
Oct 27, 2022Guru - Experienced User
1. You shouldn't need to disable bandsteering to install an extender. Most should install fine with it running.
2. what error do you get when you're trying to install the extender? Are you using wps or using their version of the installation assistant?
3. If you do want to disable bandsteering, look for the smart connect option in your router. That's netgears bandsteering. (tough to point you to a manual without having a model that you have)
