Kuroodo's avatar
Kuroodo
Tutor
Jan 02, 2020
Disabling WIFI Button
Is there a method for removing this button's functionality, or the button all-together? My cat tends to rest on the router and sometimes ends up pressing the button, turning off the wifi connection. ...
  • antinode's avatar
    antinode
    Jan 02, 2020
    > [...] tape a coin over it. [...]
       Because pressing on "a coin over it" won't press on _it_?  Or has
    your coin a suitable hole in it?
       I'd try taping a bottle-cap over the button, rather than glue or
    disassembly and other damage.
