Kuroodo
Jan 02, 2020Tutor
Disabling WIFI Button
Is there a method for removing this button's functionality, or the button all-together? My cat tends to rest on the router and sometimes ends up pressing the button, turning off the wifi connection. ...
- Jan 02, 2020
> [...] tape a coin over it. [...]
Because pressing on "a coin over it" won't press on _it_? Or has
your coin a suitable hole in it?I'd try taping a bottle-cap over the button, rather than glue or
disassembly and other damage.
Kuroodo
Jan 02, 2020Tutor
Thank you both for the ideas. I will try the bottle cap one before attempting any form of disassembly, and will report back if the ideas resolve my issue.
