rvilelas's avatar
rvilelas
disassemble the router r9000 x10
would anyone know how to disassemble the router r9000. I searched everywhere and found nothing. Is there any tutorial with images if possible? My router bricked and I need to access the seria pins on...
  • myersw's avatar
    myersw
    Sep 13, 2019
    antinode wrote:
    > [...] Is it really indicative of defect?
       I've never done this, so I know nothing, but that does not look good
    to me.
    antinode is correct in that the output does not look good. Fact that you are getting readable output says you have the serial connect setup properly, but there should not be errors and I have never hear of red eye..... ,but that maybe what is on these. In any case I am not seeing valid output other then firmware name Annapurma labs, owned by Amazon. CPU in the r9000 is from them.  Init errors are not good. Maybe time to toss in bin and move on.
