Nino67
Aug 06, 2021Aspirant
Disney+ & ESPN not working on ROKU
I have a nighthawk R7000 router and can't seem to get the Diesney+ and ESPN apps to work on my Roku any longer. Any thoughts on wha the issue might be? Firmware Version V1.0.11.126_10.2.112 ...
Aug 06, 2021Guru - Experienced User
what modem/gateway is the r7000 connected to?
Its only the roku's with issues?
Nino67
The R7000 is connected to my Arris Surfboard Modem.
Disney+ also does not work on my iPad or my windows laptop.
- plemansAug 06, 2021Guru - Experienced User
which arris surfboard? They make a lot of them.
- Nino67Aug 06, 2021Aspirant
Arris surfboard SVG2482AC
thats a modem/router combo device.
it can put you in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only use 1)
1. put the arris in modem only/passthrough mode.
2. put the netgears IP address into the Arris's DMZ
3. put the netgear into access point mode
