Nino67
Aug 06, 2021Aspirant
Disney+ & ESPN not working on ROKU
I have a nighthawk R7000 router and can't seem to get the Diesney+ and ESPN apps to work on my Roku any longer. Any thoughts on wha the issue might be? Firmware Version V1.0.11.126_10.2.112 ...
Nino67
The R7000 is connected to my Arris Surfboard Modem.
Disney+ also does not work on my iPad or my windows laptop.
Aug 06, 2021Guru - Experienced User
which arris surfboard? They make a lot of them.
- Nino67Aug 06, 2021Aspirant
Arris surfboard SVG2482AC
- plemansAug 06, 2021Guru - Experienced User
thats a modem/router combo device.
it can put you in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only use 1)
1. put the arris in modem only/passthrough mode.
2. put the netgears IP address into the Arris's DMZ
3. put the netgear into access point mode
Is this the same as settings my netgear r7000 router to bridge mode?
Thank so much for your help!!
