Nino67
Aug 06, 2021Aspirant
Disney+ & ESPN not working on ROKU
I have a nighthawk R7000 router and can't seem to get the Diesney+ and ESPN apps to work on my Roku any longer. Any thoughts on wha the issue might be? Firmware Version V1.0.11.126_10.2.112 ...
Aug 06, 2021Guru - Experienced User
thats a modem/router combo device.
it can put you in a double nat.
https://kb.netgear.com/30186/What-is-Double-NAT
options? (only use 1)
1. put the arris in modem only/passthrough mode.
2. put the netgears IP address into the Arris's DMZ
3. put the netgear into access point mode
Nino67
Is this the same as settings my netgear r7000 router to bridge mode?
Thank so much for your help!!
- plemansAug 06, 2021Guru - Experienced User
No. Bridge mode and access point mode are 2 different modes for netgear.
- Nino67Aug 06, 2021Aspirant
Thanks, was not aware I should set it to AP mode. I've had it on router mode for years with no issues. Then a month ago Disney+ and ESPN app stopped working suddenly. So why was it been working fine till recently? So confusing and frustrating.
Any other gotcha's I need to know about if I change it to AP mode. All my devices use my neatgear router. Will that mess anything up?
there's some features that get disabled in AP mode that the Arris will manage.
its one of the downfalls of AP mode.
That's why there's a couple options to try to see what works best for your situation
