Nino67
Aug 06, 2021Aspirant
Disney+ & ESPN not working on ROKU
I have a nighthawk R7000 router and can't seem to get the Diesney+ and ESPN apps to work on my Roku any longer. Any thoughts on wha the issue might be? Firmware Version V1.0.11.126_10.2.112 ...
Nino67
Aug 07, 2021Aspirant
I tried option "#3.- put my netgear router in access point mode" but that still not work, Should I undo that and try one of the other options?
options? (only use 1)
1. put the arris in modem only/passthrough mode.
2. put the netgears IP address into the Arris's DMZ
3. put the netgear into access point mode
michaelkenward
Aug 07, 2021Guru - Experienced User
As plemans says, AP mode disables several features on a router.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
The best option is probably to put the arris in modem only/passthrough mode.
