Neliz89
Dec 27, 2021Aspirant
Dispositivi Collegati
Buonasera, è da un p odi tempo che ho problemi legato alla gestione dei dispositivi collegati al mio R9000. Come potete vedere in allegato è davvero un disastro la gestione.....si sdoppiano gli ip,...
microchip8
Dec 27, 2021Master
English, please. Grazie
Neliz89
Good evening, I have been having problems managing the devices connected to my R9000 for a while now. As you can see in the attachment, the management is really a disaster ..... the IPs are doubled, the names in short, a torture! I've tried all browsers but the result doesn't change. Anyone have any advice? thank you A greeting
- FURRYe38Dec 28, 2021Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Has a factory reset and setup from scratch been performed since last FW update using a wried PC and Web browser? MS Edge or FireFox.
- Neliz89Dec 28, 2021Aspirant
Good morning, the latest version of the FW is 1.0.5.38 and I get to my R9000 router directly with the sfp fiber and provider I have Fastweb. Since the last update I have already performed a reset but without success. I've tried all browsers but the result doesn't change !!! Can you post me a screenshot of your connected devices? Just to understand if the problem is mine alone.
Thanks so much
- Neliz89Jan 08, 2022Aspirant
- DexterJBJan 18, 2022NETGEAR Moderator
Hi Neliz89, we recommend contacting our support team for further troubleshooting and isolation. You can always reach our support team via the link below if you need any technical assistance with your NETGEAR device.
https://www.netgear.com/home/contact-us/default.aspx
Dexter
