sgp9
Jan 03, 2022Aspirant
DL speed at half , hard wired to pc
My DL speeds are at half speed throught he router. I can connect directly to the pc from the modem and get 235mb dn. I connect through the router I get 95mb dn .? This wasn't always the case. I ch...
- Jan 03, 2022
Changed DNS server on router to 8.8.8.8 8.8.4.4 .. Speeds are back up 230,s dn..
thnx for the help
sgp9
The router is a Nighthawk r7000
The firmware is V1.0.11.100_10.2.100
And yes, I did a factory reset..
The Modem is an Arris TM1602A
Jan 03, 2022Guru - Experienced User
Have you powered OFF the ISP modem and Router for 1 minute or longer then power back ON the modem then router?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
