frizzo
Sep 26, 2016Aspirant
DLNA on XBox One fails to go to the next video when the previous one ends.
I have an external hard drive connected to the router and I share its contents (most videos and photos) via DLNA. I use XBox One as the client, specifically its Media Player application. I have 10 ...
- Oct 03, 2016
James,
Turning DLNA off and then back on ended up fixing the problem. I never tried the solution you mentioned.
Robert
JamesGL
Sep 29, 2016NETGEAR Employee Retired
Hi frizzo,
If you connect the drive directly to the Xbox, will you be able to play the files continuously or getting the same error?
JamesGL
Community Team
