frizzo's avatar
frizzo
DLNA on XBox One fails to go to the next video when the previous one ends.
I have an external hard drive connected to the router and I share its contents (most videos and photos) via DLNA.  I use XBox One as the client, specifically its Media Player application.  I have 10 ...
  • frizzo's avatar
    frizzo
    Oct 03, 2016
    James,
    Turning DLNA off and then back on ended up fixing the problem.  I never tried the solution you mentioned.
    Robert
