frizzo
Sep 26, 2016Aspirant
DLNA on XBox One fails to go to the next video when the previous one ends.
I have an external hard drive connected to the router and I share its contents (most videos and photos) via DLNA. I use XBox One as the client, specifically its Media Player application. I have 10 ...
- Oct 03, 2016
James,
Turning DLNA off and then back on ended up fixing the problem. I never tried the solution you mentioned.
Robert
frizzo
Oct 03, 2016Aspirant
James,
Robert
JamesGL
Oct 05, 2016NETGEAR Employee Retired
Hi Robert,
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
JamesGL
Community Team
