rblux
Nov 16, 2021Follower
DMZ keeps switching
I set up a DMZ address on the router login page. Place the wired device in the same IP address. Then the router refreshes and changes the IP address for the device which is different than the DMZ. Is there a way to make sure the device stays locked into the same IP address as the DMZ location?
1 Reply
what router do you have
How do I reserve an IP address on my NETGEAR router? | Answer | NETGEAR Support
