EchoOne's avatar
EchoOne
Follower
Aug 19, 2020
DNS and Streaming Device Issues with CenturyLink Fiber through my R8000P
I recently decided to try CenturyLink fiber in my area. I have a C4000XG modem/router combo from CenturyLink which I have disabled the wifi radios. I am having three issues with CenturyLink fiber thr...
  • antinode's avatar
    Aug 19, 2020
    > [...] I have a C4000XG modem/router combo from CenturyLink which I
    > have disabled the wifi radios. [...]
       Disabling the radios in a modem+router does not disable its router.
    (I'd expect disabling its router to disable its radios, but that'd be a
    different case.)
       Cascading multiple routers can cause multiple problems.
    > I connect the CenturyLink modem to the Nighthawk with an Ethernet
    > cord.
       There's more than one Ethernet hole on an R8000P.
       Why are you using the R8000P with the C4000XG?  If your goal is
    better wireless-network coverage, then you might want to configure the
    R8000P as a wireless access point.
       Visit http://netgear.com/support , put in your model number, and look
    for Documentation.  Get the User Manual.  Read.  Look for "Use the
    Router as a WiFi Access Point"
    > 1) I can't use Google DNS or OpenDNS on any device or even the router.
    > Once I try to change the DNS to anything but CenturyLink, I lose
    > connection.
       Can't see what you're doing to what, where.  Don't know what "lose
    connection" means to you.  I wouldn't expect DNS to be your biggest
    problem with multiple routers, but I would expect some problems.
    > When I switch my Nighthawk back over to my Cox cable modem, everything
    > just works.
       Don't know what your "my Cox cable modem" is, but if it really is a
    simple "modem", then that would be a significanly different situation
    from using a modem+router with an R8000P-as-router.
