Minka
Aug 02, 2016Tutor
DNS Errors
I am getting super frustrated. My home has several Nest products, and other smart home gadgets. We cannot connect to the internet due to a DNS_PROBE error we keep getting. I have reset the router ...
- Aug 04, 2016
Hi Minka,
Can you connect your computer directly to the modem and check if the connection is stable. If yes, connect the router again and the computer to the router then access the UI. Go to Internet settings then select use computer MAC Address under MAC address then click apply.
JamesGL
Community Team
Minka
Aug 02, 2016Tutor
One other DNS message I get is a bad_config error. I'll get the full name when it happens again.
I should also add that this system has worked flawlessly for 8+ months, but the last few days has been sketchy.
JamesGL
Aug 04, 2016NETGEAR Employee Retired
Hi Minka,
JamesGL
Community Team
