IHateArmor's avatar
Sep 22, 2021
DNS HELL
Ever since "upgrading" to V1.0.4.76_10.1.82.    The new "Armor" security is causing DNS nightmares.   It is slow and constantly block sites and downloads.   I can't even download an older version of the firmware to get back to normal functions.
Netgear needs to get that crap off their routers or its the last product I ever buy from them.
  • I've been using Netgear for two decades.  This is by far the worst experience I've had with their products.
    As an experiment I did the following steps:
    downgraded V1.0.4.52_10.1.67
    Disabled Armor - DNS issues went away
    Re-updated to firmware V1.0.4.76_10.1.82 - DNS issues came back
    downgraded again to V1.0.4.52_10.1.67 - DNS issues went away.
    A can confirm at least on my model V1.0.4.52_10.1.67 is not working properly.
    Netgear needs to get rid of Armor.
  • Update:   Downgraded to firmware V1.0.4.52_10.1.67 and the DNS issues are better.      Looks like firmware V1.0.4.76_10.1.82 is complete junk.
    • plemans's avatar
      We've seen the dns issue across multiple product lines after this latest round of updates.
      I'm sure netgear is aware of it but they don't release when fixes or if there aware of issues until the fixes actually happen.
      • IHateArmor's avatar
        IHateArmor
        Guide
  • I have the same problem............what a PIECE of GARBAGE.........total GARBAGE.
    My Netgear went from being one of the best products around to a piece of steaming SHEITE.
    FIX IT , or I will never own or recommend Netgear again.
    • FURRYe38's avatar
      Re-updated to firmware V1.0.4.76_10.1.82 - DNS issues came back < Not working. Was Armor disabled here as well?
      downgraded again to V1.0.4.52_10.1.67 - DNS issues went away. < Working. Was Armor disabled here as well?
      A can confirm at least on my model V1.0.4.52_10.1.67 is not working properly. Do you mean V1.0.4.76 doesn't work as you reported v52 working?
