nnagreg
Mar 22, 2022Apprentice
DNS Hijacking R8000P- presenting errors, requires fresh frequently
For the past several months, I've noticed the when using my router as the DNS server, it appears to act odd, "Site cannot be reached" , "DNS address could not be found. Diagnosing the problem" esp...
- Apr 18, 2022
UPDATE 4/18/2022
Work Around (Solved)
Enabled - IPV6 Auto (set to 6to4 Tunnel)
Hi All,
By enabling IPv6, the problem went away.
Hope this helps!!
Greg
Mar 22, 2022Guru - Experienced User
There is many other posts about DNS issues seen on recent 8 series router FW.
Some report that enabling IPv6 can help. Others mention reverting back to prior working FW version.
NG is aware of the DNS issues. No idea when a fix will be forth coming.
- nnagregMar 22, 2022Apprentice
ISP: Midcontinent Communications
Manufacturer: HITRONModel: CODA-45
- FURRYe38Mar 22, 2022Guru - Experienced User
CODA-45?? 82?
There should be 4 numbers to the model of this modem...
I've confirmed the Model is CODA-45 (No other numbers)
https://us.hitrontech.com/products/service-providers/coda-45-cable-modem/
Thank you!
