nnagreg
Mar 22, 2022Apprentice
DNS Hijacking R8000P- presenting errors, requires fresh frequently
For the past several months, I've noticed the when using my router as the DNS server, it appears to act odd, "Site cannot be reached" , "DNS address could not be found. Diagnosing the problem" esp...
- Apr 18, 2022
UPDATE 4/18/2022
Work Around (Solved)
Enabled - IPV6 Auto (set to 6to4 Tunnel)
Hi All,
By enabling IPv6, the problem went away.
Hope this helps!!
Greg
nnagreg
Apr 18, 2022Apprentice
******** UPDATE *************
4/18/2022
Any thoughts? Problem still exists
New Firmware applied: V1.4.3.88_1.3.50
Did a Factory reset and completely re-built the router configuration using the WEB interface.
Problem still exists using windows 11 device :
Seeing 'DNS_PROBE' errors,
Still requires F5 refresh to continue to website during first request
AND now the router does not supply my manual DNS entries to the clients.
Detail below
Advanced Internet Setup:
Get Dynamically from ISP
Use Static IP Address
IP Address 192.168.88.8
IP Subnet Mask 255.255.255.0
Gateway IP Address 192.168.88.253
| IP Address | 192.168.88.8 |
| Subnet Mask | 255.255.255.0 |
| Default Gateway | 192.168.88.253 |
| DNS Server | 8.8.8.8 |
Domain Name Server (DNS) Address
X Use These DNS Servers
Primary DNS 8.8.8.8
Secondary DNS blank
Client DHCP info:
IP = 192.168.99.10 (Client IP)
Netmark 255.255.255.0
Gateway: 192.168.99.3
DNS Server = 192.168.99.3 (Its the internal Router IP)
NSLOOKUP (new Domain names are returned immediately)
> server
Server: UnKnown
*** UnKnown can't find server: Non-existent domain
- FURRYe38Apr 18, 2022Guru - Experienced User
Seems like the router is getting a private IP address (192.168.88.#) instead of a public address, ##.##.###.###.
Looking at the modem seems like it doe not have a built in router however wondering if the ISP has it configured differently.
Can you check with the ISP to see if they have the modem configured differently and see if the modem can pass thru a public IP address?
- nnagregApr 18, 2022Apprentice
Yes, this DHCP behavior is odd with the current version of the firmware.
With my ISP, I've elected to not accept the DNS entries from the provider (Midco.net)
Good news is that I was able to resolve the problem with DNS multiple requests, see my posted down below. However, my DHCP clients still point to the router as the DNS server, odd.Thanks for the help!
Ok glad that worked.
FYI all NG routers use DNS proxy for connected device. NG may have close what you saw in recent FW version.
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
UPDATE 4/18/2022
Hi All,
Hope this helps!!
Greg
- mkrejciJul 18, 2022Tutor
Thanks, I just setup my R8000P yesterday and have had constant DNS issues with it. I am trying your suggestion regarding turning on IPV6 and will report later if it worked or not.
