nnagreg
Mar 22, 2022Apprentice
DNS Hijacking R8000P- presenting errors, requires fresh frequently
For the past several months, I've noticed the when using my router as the DNS server, it appears to act odd, "Site cannot be reached" , "DNS address could not be found. Diagnosing the problem" esp...
- Apr 18, 2022
UPDATE 4/18/2022
Work Around (Solved)
Enabled - IPV6 Auto (set to 6to4 Tunnel)
Hi All,
By enabling IPv6, the problem went away.
Hope this helps!!
Greg
nnagreg
Apr 18, 2022Apprentice
UPDATE 4/18/2022
Hi All,
Hope this helps!!
Greg
mkrejci
Jul 18, 2022Tutor
Thanks, I just setup my R8000P yesterday and have had constant DNS issues with it. I am trying your suggestion regarding turning on IPV6 and will report later if it worked or not.
