MKOCT79's avatar
MKOCT79
Follower
Aug 14, 2022
DNS is grayed out when trying to use custom dns settings
I'm trying to change my DNS settings on my nighthawk RAX48 and when I click use custom DNS settings the DNS is still Grayed out and I can't change it.
  • michaelkenward's avatar
    michaelkenward
    MKOCT79 wrote:
    I'm trying to change my DNS settings on my nighthawk RAX48 .....
    While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
    You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
    Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
    I will ask the Netgear moderator to move your message.
    In the meantime you could visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
    Check for various troubleshooting tips.
    You may have done this already. I can't tell from your message.
    I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
  • plemans's avatar
    Are you doing it through the browser?
    Trying through the app?
    do you have a screen snip showing what you're trying to do?
