BigWaveDave372
Mar 09, 2021Initiate
DNS Issue - Again
"The only explanation I can think of is that the connection from the modem refreshed which the router's settings did communicate with the modem. After you refresh or reset the router of factory defau...
michaelkenward
Mar 10, 2021Guru - Experienced User
BigWaveDave372 wrote:
What is going on with Netgear and DNS?!
Hard to know from your message. Do you have a problem that needs fixing?
