CKopp
Nov 02, 2021Luminary
DNS Issues after firmware upgrade
I recently upgraded to the V1.42.84_1.3.42 firmware verison on my router. Since the update I am seeing random DNS timeout errors (the probe errors). In most cases, the time out is replaced within 1-2...
- Jun 22, 2022
If I enable IPV6, what option should I be using?
Auto Detect?
6 to 4 tunnel or?
Nov 02, 2021Guru - Experienced User
2 things you can try.
1. enable IPv6.
2. set your own dns provider for both the standard DNS entry and the IPv6 entry.
If those don't help, then I'd downgrade.
